HIFI-FORUM » Surround & Heimkino » A/V-Receiver/-Verstärker » Onkyo » Firmware Updates 2021 | |
Firmware Updates 2021+A -A |
Keshava
#1 erstellt: 16. Jan 2021, 13:55 | |
Es gibt wieder für mehrere Onkyo AV Receivers und auch für andere Geräte neue Firmware Updates: 14 January 2021 TX-NR686, TX-RZ730, TX-RZ830, TX-NR474, TX-NR575E, TX-NR676E, TX-RZ720, TX-RZ820, TX-RZ920, TX-8270, TX-8250, CS-N575D, CR-N775D, TX-NR555, TX-NR656/HT-R695, HT-S7800/7805, TX-RZ710, TX-RZ810, TX-RZ1100, TX-RZ3100, PR-RZ5100, TX-L50/TX-L50WL, TX-L20D/TX-L20DWL(LS5200), LS7200, NCP-302, NS-6130, NS-6170, R-N855 https://www.intl.onkyo.com/support/firmware/index.html Notice of Firmware Update for TX-NR686 A firmware update for the TX-NR686 network A/V receiver is available through the unit's USB input. The latest update includes the following content: Latest Firmware Number (16 digits):1071-2000-1070-0011 As of 14 January 2021 Change login method of TIDAL for enhancing security.* *Please refer to the link below for more details. https://www.onkyo.com/manual/sup/upd/tidal_onk.pdf Fix the issue that cannot display the logo of certain TuneIn Radio stations. Improve reception capability in certain TuneIn Radio stations. Minor bug fixes and improvements stability. https://www.intl.onkyo.com/support/firmware/index.html [Beitrag von Keshava am 16. Jan 2021, 23:07 bearbeitet] |
soulparadise
Gesperrt |
#2 erstellt: 17. Jan 2021, 13:30 | |
Keshava
#3 erstellt: 10. Jun 2021, 23:05 | |
Firmware Updates 8 June 2021: TX-NR696 TX-NR797 TX-RZ740 TX-RZ840 TX-RZ3400 TX-8390 https://www.intl.onkyo.com/support/firmware/index.html Notice of Firmware Update for TX-NR696 Latest Firmware Number (16 digits):R125-0910-1140-0029 As of 8 June 2021 Adds Klipsch Optimized Mode. Please refer to the link below for more details. https://www.onkyo.com/manual/txnr595/supple_595.pdf Add search function for SONOS device on Web Setup Menu. Increase the upper limit of connectable SONOS device from 8 to 32. Fix the issue which the error of when accessing Web Setup Menu via OvrC HUB. https://www.intl.onkyo.com/support/firmware/index.html |
soulparadise
Gesperrt |
#4 erstellt: 12. Jun 2021, 07:56 | |
Mich würde der Klipsch Modus sehr interessieren und frage mich gleichzeitig, warum nicht auch andere Modelle dieses bekommen.... |
fplgoe
#5 erstellt: 12. Jun 2021, 09:23 | |
Weil er offensichtlich überflüssig ist, wenn andere Verstärker das ohne ihn hinbekommen. |
soulparadise
Gesperrt |
#6 erstellt: 12. Jun 2021, 10:18 | |
Leider gibt es diesmal parallel keine Pioneer Updates für die baugleichen Modelle, wie zb. für meinen VSX-LX 504... |
soulparadise
Gesperrt |
#7 erstellt: 29. Jun 2021, 18:23 | |
Information über den Klipsch-Modus: Onkyo Worldwide: "Einführung in den "Optimierten Klipsch-Modus" Der "Klipsch Optimized Mode" ist eine Funktion, die ab dem Onkyo TX-NR696 AV-Receiver durch ein neu veröffentlichtes Firmware-Update verfügbar ist. Wir haben eine gemeinsame Studie mit Klipsch durchgeführt, um eine Klangfeldumgebung zu schaffen, die dem Designkonzept der Lautsprecher der Klipsch-Marke Reference Series entspricht. Der Klipsch Optimized Mode wird zukünftigen Onkyo AV-Receivern, die noch in diesem Jahr erscheinen, hinzugefügt und wird als Update verfügbar sein, wenn neue Produkte der Klipsch Reference Series auf den Markt kommen. Wir werden unsere Beziehung zu Klipsch weiter stärken, um die "beste Unterhaltung zu Hause" zu bieten, die AV-Receiver bieten können." |
fplgoe
#8 erstellt: 29. Jun 2021, 18:56 | |
Nun sind Klipsch und Onkyo ja auch unter einem Dach vereint, da werden solche Verbindungen natürlich intensiviert. |
calafat
#9 erstellt: 22. Sep 2021, 15:01 | |
Ich bräuchte dringend eine Firmware mit Airplay 2 zu dem Onkyo ns-6130 (Airplay tauglich), damit die Problematik Audio-Buffering mit Apple tv 4k gelöst ist. Obwohl bereits zeitgemäß 2020/21 einige Geräte bei der Auslieferung mit Airplay 2 ausgestatten worden sind, tut sich Onkyo nun doch recht schwer daran, die ns-6130/70 Modelle und beide mit Airplay Modulen bestückt, nicht aufzurüsten. Gibt`s hierzu Neuigkeiten? Es ist doch nun wirklich an der Zeit, diesem wertvollen Gerät einen neuen Schliff zu verpassen, denke ich. Mfg. [Beitrag von calafat am 22. Sep 2021, 16:45 bearbeitet] |
soulparadise
Gesperrt |
#10 erstellt: 25. Sep 2021, 16:34 | |
Auch wenn die neuen Geräte noch nicht in Europa verfügbar sind, ist es trotzdem interessant zu lesen, was es schon für neue Updates gibt: https://www.onkyousa.com/downloads/ Firmware Update Onkyo TX-NR7100/TX-RZ50 (07-20-2021) We are pleased to offer this firmware update for the best possible performance of your Onkyo AV Receiver. This update may be installed via USB or Network. TX-NR7100/TX-RZ50 (Current Version R107-0105-0010-0029) The 07/20/2021 update will address the following: 1. The "Klipsch Optimized Mode" function has been added. Please refer to the link below for more details. https://www.onkyo.com/manual/sup/upd/combo_onk.pdf 2. Virtual Remote, Limit Mode, and HDMI diagnostic functions have been added to the Web Setup Menu. 3. Fixed the problem that the audio format of TIDAL playback becomes AAC. 4. Fixed the problem of color corruption in Dolby Vision games on Xbox. 5. Fixed a problem where the image would not be displayed when VRR was turned on for Xbox. 6. Fixed the problem where High Bit Rate Audio such as Dolby TrueHD would not be output when 4K or 8K resolution signals were input. 7. Fixed the problem where audio would not be output from the TV speakers when playing High Bit Rate Audio signals such as Dolby TrueHD in TV audio output mode. 8. Fixed a problem with the HDMI diagnostic function Source Test. https://www.onkyousa...7-20-2021_Rev1-1.pdf Firmware Update Onkyo TX-NR5100 (07-20-2021) We are pleased to offer this firmware update for the best possible performance of your Onkyo AV Receiver. This update may be installed via USB or Network. TX-NR5100 (Current Version R109-0205-0020-0029) The 07/20/2021 update will address the following: 1. The "Klipsch Optimized Mode" function has been added. Please refer to the link below for more details. https://www.onkyo.com/manual/sup/upd/combo_onk.pdf 2. Virtual Remote, Limit Mode, and HDMI diagnostic functions have been added to the Web Setup Menu. 3. Fixed the problem that the audio format of TIDAL playback becomes AAC. 4. Fixed the problem of color corruption in Dolby Vision games on Xbox. 5. Fixed a problem where the image would not be displayed when VRR was turned on for Xbox. 6. Fixed the problem where High Bit Rate Audio such as Dolby TrueHD would not be output when 4K or 8K resolution signals were input. 7. Fixed the problem where audio would not be output from the TV speakers when playing High Bit Rate Audio signals such as Dolby TrueHD in TV audio output mode. 8. Fixed a problem with the HDMI diagnostic function Source Test. Firmware Update Instructions Update the firmware via network or USB connection. "Updating the firmware via network" You can update the firmware by connecting the unit to a network. "Updating the firmware via USB connection" You need a 128 MB or larger capacity USB storage for updating. For details, see "Firmware Update" of the Instruction Manual. https://www.onkyousa...R5100_07-20-2021.pdf https://www.onkyousa.com/downloads/ [Beitrag von soulparadise am 25. Sep 2021, 16:41 bearbeitet] |
calafat
#11 erstellt: 04. Okt 2021, 11:53 | |
Es ist mir beim näheren durchgucken der download page von Onkyo aufgefallen, dass der 18. April 2019 Support für AirPlay2 beim dem NS-6130 Geräten nicht ausgeführt oder aber bewusst ausgelassen war , wobei das nachfolgende Update vom 4. Juli (leider nur zur Stabilität von Airplay) wieder zu allen gängigen Geräten versendet wurde. Ich bräuchte diesen Support dringend für meinen Apple tv 4k (6.Gen.), wegen der Verbesserung dieser notwendigen Audi-Bufferungskkapazität. Wäre das nicht fair und mit einer gewissen Toleranz verbunden, wenn diese NS-6170/30 Geräte nun endlich auch auf den Airplay 2 Standart gehoben werden könnten, wer kann man dazu anschreiben damit das Tatsache wird? Mfg. [Beitrag von calafat am 04. Okt 2021, 11:55 bearbeitet] |
soulparadise
Gesperrt |
#12 erstellt: 08. Okt 2021, 19:57 | |
Firmware Update Onkyo TX-NR6100/6050 (07-20-2021) https://www.onkyousa..._6050_07-20-2021.pdf https://www.onkyousa.com/downloads/ We are pleased to offer this firmware update for the best possible performance of your Onkyo AV Receiver. This update may be installed via USB or Network. TX-NR6100/6050 (Current Version R107-0105-0010-0029) The 07/20/2021 update will address the following: 1. The "Klipsch Optimized Mode" function has been added. Please refer to the link below for more details. https://www.onkyo.com/manual/sup/upd/combo_onk.pdf 2. Virtual Remote, Limit Mode, and HDMI diagnostic functions have been added to the Web Setup Menu. 3. Fixed the problem that the audio format of TIDAL playback becomes AAC. 4. Fixed the problem of color corruption in Dolby Vision games on Xbox. 5. Fixed a problem where the image would not be displayed when VRR was turned on for Xbox. 6. Fixed the problem where High Bit Rate Audio such as Dolby TrueHD would not be output when 4K or 8K resolution signals were input. 7. Fixed the problem where audio would not be output from the TV speakers when playing High Bit Rate Audio signals such as Dolby TrueHD in TV audio output mode. Firmware Update Instructions Update the firmware via network or USB connection. "Updating the firmware via network" You can update the firmware by connecting the unit to a network. "Updating the firmware via USB connection" You need a 128 MB or larger capacity USB storage for updating. For details, see "Firmware Update" of the Instruction Manual. https://www.onkyousa..._6050_07-20-2021.pdf https://www.onkyousa.com/downloads/ [Beitrag von soulparadise am 08. Okt 2021, 20:07 bearbeitet] |
soulparadise
Gesperrt |
#13 erstellt: 15. Okt 2021, 20:49 | |
Für einige Onkyo AV Receivers gibt es wieder neue Firmware Updates: https://www.intl.onkyo.com/support/firmware/index.html Firmware Updates 14 October 2021: TX-NR696 TX-NR797 TX-RZ740 TX-RZ840 TX-RZ3400 TX-8390 Notice of Firmware Update for TX-NR696 A firmware update for the TX-NR696 network A/V receiver is available through the unit's USB input. The latest update includes the following content: Latest Firmware Number (16 digits):R127-1011-1140-0030 As of 14 October 2021 Chromecast built-in version update to 1.52. Fix the playback format issue converted as AAC format while playing TIDAL's FLAC audio format. Für die neuen auch: https://www.onkyousa.com/downloads/ Firmware Update Onkyo TX-NR5100 (10-14-2021) We are pleased to offer this firmware update for the best possible performance of your Onkyo AV Receiver. This update may be installed via USB or Network. TX-NR5100 (Current Version R112-0306-0030-0030) The 10/14/2021 update will address the following: 1. Chromecast built-in version update to 1.52. 2. Fix the no sound and video issue via eARC connection from SONY TV. https://www.onkyousa...R5100_10-14-2021.pdf Firmware Update Onkyo TX-NR6100/6050 (10-14-2021) We are pleased to offer this firmware update for the best possible performance of your Onkyo AV Receiver. This update may be installed via USB or Network. TX-NR6100/6050 (Current Version R110-0206-0020-0030) The 10/14/2021 update will address the following: 1. Chromecast built-in version update to 1.52. 2. Fix the no sound and video issue via eARC connection from SONY TV. https://www.onkyousa..._6050_10-14-2021.pdf Firmware Update Onkyo TX-NR7100/TX-RZ50 (10-14-2021) We are pleased to offer this firmware update for the best possible performance of your Onkyo AV Receiver. This update may be installed via USB or Network. TX-NR7100/TX-RZ50 (Current Version R110-0206-0020-0030) The 10/14/2021 update will address the following: 1. Chromecast built-in version update to 1.52. 2. Fix the no sound and video issue via eARC connection from SONY TV. https://www.onkyousa...-RZ50_10-14-2021.pdf https://www.onkyousa.com/downloads/ [Beitrag von soulparadise am 15. Okt 2021, 20:56 bearbeitet] |
soulparadise
Gesperrt |
#14 erstellt: 24. Nov 2021, 22:10 | |
Firmware Updates 24 November 2021: https://www.intl.onkyo.com/support/firmware/index.html SUPPORT Firmware Updates Update History 24 November 2021 TX-NR686 Firmware Number: 1071-3000-1070-0011 TX-RZ730 Firmware Number: 1091-3000-1070-0011 TX-RZ830 Firmware Number: 1091-3000-1070-0011 TX-NR474 Firmware Number: 1141-9010-0070-0011 TX-NR575E Firmware Number: 1141-9020-0070-0011 TX-NR676E/HT-R997 Firmware Number: 1141-9020-3070-0011 TX-RZ720 Firmware Number: 1141-9020-3070-0011 TX-RZ820 Firmware Number: 1141-9020-3070-0011 TX-RZ920 Firmware Number: 1121-6010-3070-0011 TX-8270 Firmware Number: 1131-9000-0070-0011 TX-8250 Firmware Number: 1101-5000-0000-0011 CS-N575D Firmware Number: 1701-6000-0000-0011 CR-N775D Firmware Number: 1801-6000-0000-0011 TX-NR555 Firmware Number: 2170-6050-7100-0011 TX-NR656 Firmware Number: 2170-6050-7100-0011 HT-S7800/HT-S7805(HT-R695) Firmware Number: 2170-6050-7100-0011 TX-RZ710 Firmware Number: 2170-6050-7100-0011 TX-RZ810 Firmware Number: 2170-6050-7100-0011 TX-RZ1100 Firmware Number: 2190-6000-5080-0011 TX-RZ3100 Firmware Number: 2190-6000-5080-0011 PR-RZ5100 Firmware Number: 2190-6000-5080-0011 TX-L50/TX-L50WL Firmware Number: 2160-7030-3080-0012 TX-L20D/TX-L20DWL/(LS5200) Firmware Number: 2150-7020-3080-0012 LS7200 Firmware Number: 2180-7040-2070-0012 NCP-302 Firmware Number: 2150-9000-0000-0011 NS-6130 Firmware Number: 2140-9000-0000-0011 NS-6170 Firmware Number: 2140-9000-0000-0011 R-N855 Firmware Number: 2160-9000-0000-0011 https://www.intl.onkyo.com/support/firmware/tx-nr686.html Notice of Firmware Update for TX-NR686 A firmware update for the TX-NR686 network A/V receiver is available through the unit's USB input. The latest update includes the following content: Latest Firmware Number (16 digits):1071-3000-1070-0011 As of 24 Novenber 2021 Increase the upper limit of connectable SONOS device from 8 to 32. Fix the playback format issue converted as AAC format while playing TIDAL's FLAC audio format. Improve reception capability in certain TuneIn Radio stations. Minor bug fixes and improvements stability. https://www.intl.onkyo.com/support/firmware/index.html |
soulparadise
Gesperrt |
#15 erstellt: 25. Nov 2021, 00:59 | |
calafat
#16 erstellt: 25. Nov 2021, 17:12 | |
Gestern neues update von Onkyo für den ns-6130 erhalten, war überrascht wegen erneutem support.Doch, airplay 2 war nicht integriert, schade. Dafür klappt die Verbindung mit TunelnRadio und dem "SatinJazz Lady Voice" Kanal wieder. Mfg. |
TX-RZ830 aktuelle Firmware lpop am 18.12.2022 – Letzte Antwort am 18.12.2022 – 2 Beiträge |
TX-NR555 oder TX-NR656? HellsDelight666 am 25.03.2017 – Letzte Antwort am 27.03.2017 – 6 Beiträge |
Onkyo TX-SR373, TX-NR474, TX-NR575E - Einsteigerklasse Modelle 2017 Igelfrau am 22.02.2017 – Letzte Antwort am 14.12.2021 – 44 Beiträge |
Firmware update TX-RZ710 hagilife am 01.04.2017 – Letzte Antwort am 13.04.2017 – 3 Beiträge |
TX-NR555, Firmware error GDouglas am 08.08.2018 – Letzte Antwort am 11.10.2018 – 7 Beiträge |
Onkyo TX-NR5010 | TX-NR3010 | TX-NR1010 plotteron am 27.06.2012 – Letzte Antwort am 13.06.2018 – 2972 Beiträge |
Oberklasse 2016 Onkyo TX-RZ1100, TX-RZ3100 und PR-RZ5100 Sonophil am 28.12.2015 – Letzte Antwort am 16.02.2024 – 1798 Beiträge |
TX-NR676E vs. TX-RZ720 (enormer Preisunterschied) rahffde am 07.12.2017 – Letzte Antwort am 13.02.2018 – 20 Beiträge |
Onkyo TX-NR1030 oder TX-RZ1100 iJoker am 25.02.2017 – Letzte Antwort am 25.02.2017 – 2 Beiträge |
Onkyo TX-NR5007, TX-NR3007, TX-NR1007 Netzwerk-AV-Receiver Gardi am 17.08.2009 – Letzte Antwort am 19.05.2010 – 24 Beiträge |
Top 10 Threads in Onkyo der letzten 7 Tage
- Firmware Updates 2022
- Firmware Updates 2023
- Firmware Updates 2021
- Onkyo 2022: TX-RZ70 (11.2) und TX-RZ90 (13.2) mit Auro3D und Dirac Single/Multi BC
- Onyko TX SR606 kein Setupmenü auf TV
- Der "Onkyo TX NR 616" Stammtisch
- Information und Warnung zu HDMI-Board bei TX-NR708/808/1008
- ONKYO TX NR 636 - Katastrophe ARC und HDMI
- AVR schaltet sich über Fernbedienung nicht ab!
- Wii an Onkyo Receiver
Top 10 Threads in Onkyo der letzten 50 Tage
- Registrierte Mitglieder925.871 ( Heute: 6 )
- Neuestes MitgliedMatu1804
- Gesamtzahl an Themen1.551.506
- Gesamtzahl an Beiträgen21.548.091
