HIFI-FORUM » Stereo » Elektronik » Analogtechnik/Plattenspieler » B&O Plattenspieler geht nur auf einen Kanal | |
B&O Plattenspieler geht nur auf einen Kanal+A -A |
Teabreak
#1 erstellt: 18. Jul 2009, 15:21 | |
Besitze seid neuesten einen schönen B&O Plattenspieler einen Beogram 1902, er war ein Bastelobjekt da das Furnier schon sehr in Mitleidenschaft gezogen wurde es blättert ab. Leider spielt er nur auf einen Kanal der Rechte bleibt vollkommen stumm.Er ist an Din Adapter an eien Vollverstärker angeschlossen ein anderer Adapter brachte auch keine Fehlerbehebung. Was kann der Player haben bzw . was ist die Ursache dafür? |
tri-comp
#2 erstellt: 19. Jul 2009, 06:36 | |
Hi, You have 4 possible causes: 1) Pick-up is defective. Remove it and looking at the front of the pick-up arm you will see 4 connection-pin's that make the contact with the pick-up. The outer contacts are ground but the 2 center-pin's are right and left output (counting from the left). Start the player (with pick-up still removed) and use a small needle to gently touch the center-pins. You should hear a hum in each channel. If you do, the pick-up is defective. If one channel is still missing look at 2) 2) Wire is broken-off inside the DIN-plug. Open it and verify Left-channel (Pin-3) and Right-channel (Pin-5) besides Screen/Ground (Pin-2) wires are in place. If not, resolder. If they are OK look at 3) 3) Inside the player is a Muting-Switch. It has been known to cause problems like this. Of course you need to take the player apart to check the function of this switch. Be carefull, the pick-up arm is fragile! Check with an Ohm-meter that the muting-switch doesn't short the faulty channel to ground. Repair the switch if defective or remove connections to it. You will hear some noise from the pick-up landing if the switch is missing but at least you have sound in both channels. If switch is OK look at 4) 4) Thin wire from front of tone-arm to where the muting-switch is connected is broken inside the tone-arm tube. NOW you are in trouble. Go buy another turn-table. mfg, /tri-comp |
holymoly_
#3 erstellt: 19. Jan 2010, 17:13 | |
Hallo Teabreak, habe mir auch einen Beogram 1902 zugelegt und über einen 5-pol. DIN/Cinch-Adapter (mit Erdung) an meinen Verstärker angeschlossen. Ich habe exakt das gleiche Problem: Der linke Kanal geht – der rechte ist tot. Nun meine Frage: Dein Eintrag ist schon sehr alt, hat sich in der Zwischenzeit mal herausgestellt, woran es liegt? Vielen Dank schonmal und Grüße, Vero |
B&O Nuovo am 26.11.2013 – Letzte Antwort am 25.03.2014 – 28 Beiträge |
Reparatur B&O 4004 wywhm am 26.01.2022 – Letzte Antwort am 27.01.2022 – 3 Beiträge |
B&O Beomaster 5000 Plattenspieler Switch Benni_Jay am 02.03.2016 – Letzte Antwort am 02.03.2016 – 3 Beiträge |
Neuer, alter B&O Plattenspieler, limitiert kaefer03 am 12.10.2020 – Letzte Antwort am 13.10.2020 – 22 Beiträge |
B & O Beogram 7000 chrisradio am 25.11.2012 – Letzte Antwort am 30.11.2012 – 4 Beiträge |
Hilfe : B&O und Akai??? Gonno am 21.11.2003 – Letzte Antwort am 21.11.2003 – 3 Beiträge |
HELP! B&O Beogram 6000 roman165 am 12.04.2015 – Letzte Antwort am 21.04.2015 – 9 Beiträge |
B&O Beogram und Anschlusskabel Badhabits am 08.11.2005 – Letzte Antwort am 06.04.2006 – 8 Beiträge |
B&O Nadel für Beogram4002 Gonno am 25.10.2003 – Letzte Antwort am 26.10.2003 – 3 Beiträge |
Plattenspieler? o Ja o Nein o Vielleicht A_Koch am 24.11.2014 – Letzte Antwort am 19.02.2017 – 130 Beiträge |
- Plattengewicht Ja oder Nein
- elliptisch, sphärisch, hä?
- Hilfe: Plattenteller eiert
- Registrierte Mitglieder926.001 ( Heute: 2 )
- Neuestes MitgliedThorsten128
- Gesamtzahl an Themen1.551.820
- Gesamtzahl an Beiträgen21.555.189
